Prop shaft zerks.
Any reason not to run a zerk in the front propshaft? I know the manual says to remove the plug, put a zerk in, grease it, then put the plug back in. I popped a straight zerk in there and left it. Doesn't seem to vibrate any and doesn't look like it comes close to touching anything so is there any reason not to leave it in there? The rear shaft has one from the factory, I'm just a little curious why the front doesn't.
So far 20k on my rebuilt at home shaft, so far so good ;-)
Got them both Mike, although the zerk in the rear universal seemed to be frozen. Pumped a ton of grease all over before it popped open. Was just curious because the rear shaft has a straight zerk and the front has a plug. Just thought that was odd. As far as I know they come from LR set up like that. Just wondered the logic behind it, if there is any ;-)
Alex_M
11-15-2023 11:08 AM
aaveryy
05-12-2007 07:51 AM
