Puff/compression sound under exhaust manifold
For starters I have a 2002 discover II with 226k miles. I do oil and filter changes every 3k miles, mobile 10w-30 and K&N filter, along with cleaning my K&N air filter, spark plugs (Bosh 4 Platinums) have about 15k miles on them with magnacore wires same time as plugs. I have not had the head gaskets replaced in the 4 years I have owned it.
Issue: about 2 weeks ago (2 weeks after seafoam induction and what sounded like a valve rattle that went away) I noticed a puffing sound coming from the passenger side of the engine, replaced the exhaust manifold gasket, puffing sound stayed. Used a mirror to see under the exhaust manifold (around #4 cyl) sprayed a mist of carb cleaner and saw the mist being pushed away from the engine. I am not sure if it is due to the head gaskets needing to be replaced or if it is pushing compression out another way.
Unfortunately I am on a tight budget being a college student, any help/advice would be greatly appreciated. My dad and I have been working on a CJ7 jeep rebuild and trying to finish it up, so their has come at a very inconvenient time. Thank you in advance for the help
Sounds like a headgasket. I've seen videos on here showing the sound you are describing. It was the compression ring on the HG that let go. Heard of it a few other times. Sorry to say that. Do a compression test to see if that cylinder is lower than the rest. If it is.. you may very well have your answer.
Thank you zeroone. I'll check the compression here in the next couple of days, we were thinking it was the HG, just wanted another opinion. Will get back with what we find from the tests after we get to it. Also, with the amount of miles on it, should I expect to need to turn back around and prepare for something else that may also be serious, I'm expecting roughly 12-16 hours of labor and about $400-$800 in parts and getting the heads checked after it's torn apart. Please correct me if my assumptions are wrong or if their is more that I should expect.
That is probably just the "Y" pipe connection on that side.
Those come loose from thermal expansion / contraction.
If you try to tighten the bolts - they will probably snap.
As the rover is running - you can leave it be probably.
Get a rubber hose and use that to zero in on the sound location.
I had to drill out the studs in the manifold on my D1 and re-tap the threads when I changed the CC
This may give you some help
http://jeffreyfall.com/landrover
