Pulling my hair out
Pulling my hair out
I did the Shuttle Valves, Amigos were intermittent before I did them. After about 3 days they stayed on all the time. Had them scanned, wish I had the codes, but was told that the ABS Modulator was bad. Just did the Option B and guess what, still on. CDL, CB and Exhaust leak have all been fixed/installed, why does the Rover taunt me so. Still taking it Off Road on Saturday, we will see what happens.
Without the ABS codes, it is difficult to determine what exactly is the problem. The sensors may need cleaning or adjustment, but from the "the ABS Modulator was bad" statement, it is more than likely either the shuttle valves, or the circuit board. Both of which are covered in the ABS sticky, depending on the specific code.
How would you not have 4wd its a full time set up and unless he removes the drive shaft he'd be in 4wd. If he did the cdl wrong it would not engage in locked but still be in hi or lo 4wd. His traction control won't work but he will have 4wd.
*To save face, it was uphill, in the mud, with street/summer tires. Once on wet grass, I was able to pull the Escape with trailer attached up the hill.
Yes, that I know, but without the aid of TC it will not stop the wheel that loses traction from spinning. Again, I was looking to be proved wrong but wanted to throw it out there. I watched my friend not being able to get up a small snowy incline in his Disco when he had the Amigos come calling.
I had a local shop with the high-end Snap-on scanner do the 3 stage bleed on the Rover.
1. Manual Bleed
2. ABS Modulator Bleed
3. Power Bleed
Went through a full bottle of Valvoline Synthetic Dot 4 brake fluid, but the lights are still off and the brakes are 100 times better than they were. Only cost me $56.00, including 2 extra bottles of brake fluid.
1. Manual Bleed
3. Power Bleed
