question about suspension parts
I picked up some used suspension components last week because I could not refuse the price (free) and I like to grab spare parts whenever I can. I was told the vehicle had a lift kit installed and the shop returned the old equipment. basically there are 4 shocks, 4 springs, and a stabilizer (as well as all hardware and bushings). now here is my question the springs are in OME boxes and the 2 boxes are different lengths however 3 of the springs are the same length but one of them is about 2 inches longer, is this normal? or do you think the shop mixed up one of the springs with another vehicles?or maybe something else is going on like 3 are shot?
they should all be the same length in pairs. The drivers side spring may be a touch taller on the front. They probably threw the old springs in the new boxes. Pretty sure the fronts are longer, but whatever the case, you either have a collapsed or sprung spring.
Do you need new shocks and springs?
(I am sure mine are plenty past due) but I just grabbed them because they are free. I need a new stabilizer so I thought maybe I would test that one out but if I do use it, it will only be until tax return (unless it is no good). I have been without a vehicle too many times due to waiting for parts to ship, so now if I can get spare parts as backups I do. I just don't want to waste space keeping parts that I know are bad.
When i pulled my factory springs out of mine when i lifted it the drivers front spring was about 1-2" taller than the rest when they were sitting on the ground with no weight on them. The truck still sat level i dont know how but it did. Im guessing it was a different weight spring. I would say try putting them on your truck it only takes about an hour or so to do. If it sits lower than before trash them there no good if it sits higher leave them in there.
fastrx7man
01-28-2012 12:49 PM
roverintherocks
12-08-2010 10:36 AM
