Question on prop shaft.
Old Aug 10, 2012 | 09:22 AM
ZGPhoto's Avatar
Also, since the front shaft is different on a 4.6 and a 4.0, how does it perfectly fit 99-04?
Old Aug 10, 2012 | 10:01 AM
cagusmc's Avatar
Thanks for the information. I will look at the shaft today.
Old Aug 10, 2012 | 11:48 AM
drowssap's Avatar
if you want a long shaft because of a lift order an 03-04 shaft
Old Aug 10, 2012 | 02:54 PM
lr2001silver's Avatar
Banned
Call Justin at dynamic drive line and ask your questions.
Old Aug 10, 2012 | 03:43 PM
cagusmc's Avatar
Thanks for the contact info. I see they sell on ebay too.
Old Aug 10, 2012 | 04:27 PM
cagusmc's Avatar
I was finally able to crawl under the vehicle to check if the up-grade was done. It does have Zerk's on the u-joints which is good. I will hit them with a grease gun later today. Thanks again for all the help.
Old Aug 10, 2012 | 05:13 PM
antichrist's Avatar
If you're not going to rebuild it as recommended, then be sure you grease them as described in the propshaft rebuild post.
Old Aug 10, 2012 | 09:54 PM
AZRover's Avatar
Originally Posted by roverguy67
...two weeks later later his failed. He had it towed to the dealor.. price to get it fixed: $7990.00. It's much cheaper to just replace.... just sayin....
That's a hell of a price to say, "I told you so"!!!
Old Aug 10, 2012 | 10:13 PM
jbkroh's Avatar
Default removing now
well we just finished getting the propshaft out...rebuild for tomorrow
no gease fittings but everything was still real tight, maybe i'll just put it back...........kidding
Old Aug 11, 2012 | 12:27 AM
Banned
That is not a fun rebuild be very careful not to pry very hard on it, chances are you will break something if you do. Good luck with your rebuild!
