quick drive shaft question
Old 03-11-2015, 11:51 AM
drowssap's Avatar
Default quick drive shaft question
the slip joint faces the differential or the transfer case?
Old 03-11-2015, 11:58 AM
bballjames's Avatar
the male end is on the t-case side, and the female end is on the axle side
Old 03-11-2015, 12:01 PM
dusty1's Avatar
front drive shaft has different bolt pattern on each end....so no way to get it backwards.
just be sure not to install it upside down.
Old 03-11-2015, 02:16 PM
ralphobell's Avatar
Ah crap! That explains why all my grease leaks out of it....I have it installed upside down.
Old 03-11-2015, 02:18 PM
dusty1's Avatar
duct tape will fix that........just don't put that on backwards.
Old 03-11-2015, 02:22 PM
drowssap's Avatar
Thankyou now i just have to dig a hole under the truck.
Old 03-11-2015, 04:28 PM
Now now Dusty, behave
Old 03-12-2015, 06:24 AM
drowssap's Avatar
i hate working outside, well thank you got it in a little heavier than the stock
Attached Thumbnails quick drive shaft question-img_20150311_152029562_hdr.jpg
Old 03-12-2015, 06:40 AM
dusty1's Avatar
Who made that one?
Old 03-12-2015, 11:33 AM
drowssap's Avatar
Im not sure i got a @ BPU it there middle grade, down was stock, up was tom woods cardone. I was surprised at the quailty .
Quick Reply: quick drive shaft question
