Quick question about locking the diff...
I just bought my first Land Rover 3 weeks ago, and I have been enjoying it tremendously. I have a quick question, and I am looking for advice.
[Please do not attack me, this is an honest question and asinine remarks will be ignored]
When should I lock the differential? I am not a off-road gear head, so I have never had a vehicle with a locking diff. I find that low gear gets me through anything I need to climb over or when driving in snow. I assume that when I move the gearbox to locking position (slide it left) it will make all the wheels spin at the same speed ALL the time. Is this wise? I probably will never go rock climbing for fear of rolling this baby, but heavy snow will likely occur frequently. What scenarios do you guys have for when I should lock the diff?
Thanks in advance.
-Von
Thanks in advance.
-Von
I don't live far from you, just north in baltimore. Frankly, for the amount of snow that we get and for the type of driving that you'll do, you'll never need your diff lock. If you never go off road, at least engage your t-case to low gear and diff lock every few months so that it doesn't seize up. As far as use, I lock the transfer case in high (just slide to the left) for deep snow or sand driving. Low gear and diff locked only for very deep mud or rock crawling where you're under 5mph. Your truck is AWD all the time so other than excercising the lever you probably won't need it unless we get a big Noreaster or a blizzard.
Check out atlantic british, I've attached the link. Not cheap, the cheapest cross-bars to attach are still over $300, all depends what you need it for. I don't have any, never really needed it. I've towed a boat and motorcycle previously but never had a need for roof storage...specifically why I wanted an SE and not SE7. More storage.
http://www.roverparts.com/ProductLis...y=Roof%20Racks
I use Thule 450 mounts with 50" crossbars. I can transfer it between my '03 and my wife's '06 outback. Rack goes on and off in less than 5 minutes, so I only put on when skiing so i don't lose anymore mpg's when driving around town. It was a no brainer for me since I've been using Thule for over20 years.
With this mount system I can load my skis stacked together and the bindings have enough clearance not to hit the roof.
I were to purchase again, I'd get longer crossbars (if they were only going on Discovery, but they wouldn't have worked with the Subie).
ORIGINAL: ucfmethod
...it will make all the wheels spin at the same speed ALL the time.
What happens if T/C off (CDL engaged) and a tire is off the ground, what happens to the power? Does more power go to the tire with traction on the ground for the same axle?
