Radiator Shopping
Old 12-18-2012 | 10:43 PM
Madlands's Avatar
Default Radiator Shopping
I've decided it's time to replace the radiator in my 04. I've seen a few on eBay in the $165 range, while others on rover parts sites are more $300 range. Where's the best (cheapest and good quality) place to order from?
Old 12-18-2012 | 10:44 PM
909wheeler's Avatar
Old 12-18-2012 | 11:09 PM
borchera's Avatar
We replaced, ours in addition to all the cooling hoses, with a Nissen. No complaints.
64313A Nissens - Radiator At StylinTrucks.com
2003 Discovery 131K with all high miles services complete.
Old 12-18-2012 | 11:18 PM
Madlands's Avatar
Thanks for the quick replies. I've got to say the $126 radiator sounds too good to be true. Have you ever bought from there 909wheeler? I never thought to check stylintrucks for rover parts. After looking at AB they show there being a radiator for SAI and one without SAI, is there really a difference I haven't seen that anywhere else?
Old 12-18-2012 | 11:25 PM
909wheeler's Avatar
No I havent but somebody on here did and said it was great. I'll be ordering mine in a couple of weeks.
As for SAI vs. non-SAI most radiators will be made for SAI and the sensor bung capped for non-SAI models.
Old 12-18-2012 | 11:42 PM
Racer X's Avatar
I have the Genesis Auto Parts radiator, it's still leak free, and in the summer with the 180 degree t-stat, my temps were nice and cool.
Also, I paid almost $35 more when I ordered mine...
Old 12-19-2012 | 08:46 AM
04duxlr's Avatar
I just bought a Nissens from Lucky8. Justin gave me a great deal. Nissens has an excellent reputation so it was worth the little extra for me over the Chinese bargain brands. And yes, it included the SAI temp port which comes with a threaded plug installed for non-SAI applications.
Old 12-19-2012 | 09:48 AM
Racer X's Avatar
Just so you know, Nissens from time to time does repackage other manufacturers radiators in their own boxes. If you call/ write them they'll tell you the origin of your radiator.
I can say that it happens more with low volume part numbers, so I wouldn't be surprised to hear it's the case with LR radiators, too.
Old 12-19-2012 | 10:02 AM
You have to remember, the economey sucks and for people to come out with really cheap radiators, they have to cut corners, lessor quality material and Made in China.
If you want a good radiator, one that is original then go to British Parts of Utah where you can buy one made in Scotland and I believe one of the original suppliers for Rover.
I bought one from BPoU for $280, still way under Rovers price, and won't have to worry about it for another 100,000 mils plus.
Don't for get to switch tp Peak or one of the other coolants and stay away from Dexcool, also buy a new 180 soft spring t/stat for even better performance.
Old 12-19-2012 | 10:14 AM
04duxlr's Avatar
Well it certainly came in a very nice box. They included the hardware, including stainless steel nuts, which seemed like a nice touch. The last bargain radiator I bought was for a 1988 Toyota 4Runner and it used a larger radiator cap instead of the OEM one (which was problem until I figured out that there are only 3 radiator cap sizes), required modifications to make the shroud fit, and required a little "re-contouring" of the underside hood bracing before it would close. The quality of the Nissens one was far superior, so if it is from China they found a good factory.
