Radio Troubleshooting ...
My radio unit - Harmon Kardon with CD player and tape - will not turn on. (I just bought this vehicle).
I also get some kind of static very quiet noise from the speakers, you can barely here it, sounds like line noise.
The PO said the stereo worked intermittently.
I pulled the radio head unit from the dash, and confirmed that the constant power, and Aux have power and that my ground is good.
How do I test the amp? or the head unit?
If I give the head DC power and ground should it come on? Or does it rely on a signal from the amp to work?
My buddy says he has the same issue and replaced his amp, and everything worked again!
Clock? Its on, not sure if it tells the time. So many other things to fix! LOL
Head unit does not turn on.
I Just went to a Land Rover Addicts house (he as at least 9) and bought a head unit from him. Plugged it in and it works.
The old amp also works. So it looks like it was the head unit.
