Rear axle seal leak -Need new hub assy?
Old Sep 26, 2008 | 07:44 PM
98xc800's Avatar
Default Rear axle seal leak -Need new hub assy?
I have developed a leak from my rear axle seal. Do I have to replace the entire hub assembly? Are they truly unserviceable?
The local dealer quoted me a price of $650.00 for one! Where would the best place to order from be?
Old Sep 26, 2008 | 08:08 PM
Default RE: Rear axle seal leak -Need new hub assy?
Which seal is leaking? Front or side?
Old Sep 27, 2008 | 08:37 AM
If your axle seal is leaking, it is a new hub that is needed.
How mechanical are you, the hub is easy to replace and can be bought for around $400 for Rover connection, including a new speed sensor.
Old Sep 27, 2008 | 11:49 AM
http://www.roverparts.com/Parts/TAY100050.cfm
Old Sep 27, 2008 | 01:19 PM
98xc800's Avatar
I have no problem tackling complicated mechanical tasks, so I am confident in doing the hub swap. Thanks for the replies.
Old Sep 29, 2008 | 10:48 AM
NiteTrain's Avatar
if you have a leaking axle seal you have to replace the whole hub for $400?!?[:-] do discos have inner axle seals?
Old Sep 29, 2008 | 12:01 PM
With DII's you need to replace the whole hub as one unit.
DI's you just replace seals. Yet another reason DI's are better than DII's.
Old Sep 29, 2008 | 12:57 PM
NiteTrain's Avatar
there has to be a cheaper way to stop a axle tube oil leak than a new $400 hub.
Old Sep 29, 2008 | 12:59 PM
Yes there is. $350 at AB. Click the link that I postedin this thread.
Old Sep 29, 2008 | 01:33 PM
NiteTrain's Avatar
$350 for a simple problem is also unacceptable. what about aftermarket off-road axle seals that have a zerk fitting so you can grease to keep out mud? They cost about $50/pair. I can't remember who makes them, I'll try and find a link.
