Rear Bumper Cover Swaps
My recent 2003 SE purchase included a bumper cover to replace the badly cracked original. Based on the tail lights in the replacement, they are from a 99-02. According to Rave, there is a difference between the early and late covers. Since I'm 2000 miles from my garage and real tools, and only have a snowy wet parking lot to work in, I'm hoping that someone can give me a definitive answer on compatibility between the early and late covers. If I were home, I'd just pull it and see, but I'd like to avoid fruitless work if possible.
If it helps, I pulled a steel bumper off a 2000 and it was a direct fit to a 2003.
You're in luck.
The black bumper cover is compatible for all DIIs, '99-'04. Take a look at the bumper-mounted lights in the '99-'02 bumper (from the backside of the bumper). They're held in place by spring clips only; no tools required. You can remove the lights from both bumpers and snap the lights from your '03 into the replacement cover. Easy peasey. Plug and play. |
Originally Posted by mln01
(Post 893724)
You're in luck.
The black bumper cover is compatible for all DIIs, '99-'04. Take a look at the bumper-mounted lights in the '99-'02 bumper (from the backside of the bumper). They're held in place by spring clips only. You can remove the lights from both bumpers and snap the lights from your '04 into the replacement cover. Easy peasey. Plug and play. |
As I thought more about it, I realized why there might be a second part number
In the facelift trucks, there was a parking distance monitor option available. That required sensors mounted in the bumper cover. But if your '03 doesn't have that feature it's irrelevant. |
I did the swap yesterday and it went as smoothly as you could hope. With a little care, the plastic rivets are reusable, and for the ones that were already broken, NAPA's wall-o'-scrivets got me a worthy replacement.
Thanks for all of the input. |
