Rear Bumper Cover Swaps
Old Mar 19, 2024 | 02:51 PM
H20nSnow's Avatar
Default Rear Bumper Cover Swaps
My recent 2003 SE purchase included a bumper cover to replace the badly cracked original. Based on the tail lights in the replacement, they are from a 99-02. According to Rave, there is a difference between the early and late covers. Since I'm 2000 miles from my garage and real tools, and only have a snowy wet parking lot to work in, I'm hoping that someone can give me a definitive answer on compatibility between the early and late covers. If I were home, I'd just pull it and see, but I'd like to avoid fruitless work if possible.
Old Mar 19, 2024 | 03:19 PM
ahab's Avatar
If it helps, I pulled a steel bumper off a 2000 and it was a direct fit to a 2003.
Old Mar 19, 2024 | 05:31 PM
mln01's Avatar
You're in luck.
The black bumper cover is compatible for all DIIs, '99-'04.
Take a look at the bumper-mounted lights in the '99-'02 bumper (from the backside of the bumper). They're held in place by spring clips only; no tools required.
You can remove the lights from both bumpers and snap the lights from your '03 into the replacement cover. Easy peasey. Plug and play.
Old Mar 19, 2024 | 05:35 PM
H20nSnow's Avatar
Originally Posted by mln01
You're in luck.
The black bumper cover is compatible for all DIIs, '99-'04. Take a look at the bumper-mounted lights in the '99-'02 bumper (from the backside of the bumper). They're held in place by spring clips only.
You can remove the lights from both bumpers and snap the lights from your '04 into the replacement cover. Easy peasey. Plug and play.
Yep, I know about the ease of swapping the lights. I wasn't worried about that. I only mentioned it as ID-ing it as an early cover. You gave me the real answer I was looking for. Thanks!!!
Old Mar 19, 2024 | 08:16 PM
mln01's Avatar
As I thought more about it, I realized why there might be a second part number
In the facelift trucks, there was a parking distance monitor option available. That required sensors mounted in the bumper cover. But if your '03 doesn't have that feature it's irrelevant.
Old Mar 24, 2024 | 08:15 AM
H20nSnow's Avatar
I did the swap yesterday and it went as smoothly as you could hope. With a little care, the plastic rivets are reusable, and for the ones that were already broken, NAPA's wall-o'-scrivets got me a worthy replacement.
Thanks for all of the input.
Erikleonard
Jul 18, 2023 10:30 AM
Disco2SE
Apr 13, 2017 06:45 PM
Matty37221
Dec 25, 2014 11:06 AM
Matty37221
Oct 3, 2011 04:26 PM
ggardner1221
Mar 7, 2011 06:54 PM
