Rear Bumper replacement question...
Old Jan 6, 2026 | 08:59 PM
douglash's Avatar
3rd Gear
I put the sensors in a stock plastic replacement bumper when I broke mine a long time ago. (non 03/04 bumper, so no sensor holes...and plastic not metal, but shouldn’t be much different should it?)
It was as simple as drilling the right sized hole in the right spot. Then whatever doo-hickey mounted behind it, I put back there, stuck it on, snapped it in.
With the metal, drilling, you’ll have to corrosion protect /prime / paint the hole you drill and make sure not to “walk” the drill around to ruin the finish of your nice new bumper. But it should be possible. I remember having to use sikaflex or something to stick on the bracket that was on the interior of the bumper.
Thanks mate. Yeah, I figured it's straight forward.. shouldn't be any other issues. Will use a step up drill bit. I've read that it's a 27mm hole and then will protect the steel bumper where the powder coating is toasted.. Sikaflex should be fine or I'll use auto silicone.
goatman
Mar 30, 2020 08:54 PM
Drillbit
Aug 17, 2015 12:32 PM
bcolins
Jun 22, 2013 08:55 PM
LRD2&ME
Nov 23, 2011 09:44 PM
jw928
Feb 16, 2009 01:26 AM
