rear end question
Old Jan 20, 2010 | 09:14 AM
JumPeR04's Avatar
Default rear end question
Hey guys I went to the Orielly to get the rear end bears and seals so they chouldnt found under Lr so they ask me who make the rear end and model so they chould look it up or should take out the bears let them look at them see if they have them
Old Jan 20, 2010 | 10:49 AM
Exactly what bearings and seals are you looking for?
If it is for leaking hubs, you will have to buy a used or new hub.
You can look on Atlantic British and find what you need.
Old Jan 20, 2010 | 11:21 AM
antichrist's Avatar
Man, sorry, forgot to reply to your PM.
Pinon bearing PN's are:
Input flange end: cup - M88010; cone - M88046
Ring Gear end; cup - HM801310; cone - HM801346X
Old Jan 20, 2010 | 11:28 AM
JumPeR04's Avatar
It whould be inner / outer bearing in the hub so there no way change them out also mike did you get my PM
Old Jan 20, 2010 | 02:36 PM
antichrist's Avatar
oh, hub bearings. Timken SET37 or SKF BR37
Two sets per hub.
About $13 or so per set.
Old Jan 20, 2010 | 04:06 PM
JumPeR04's Avatar
Sweet thanks antichrist and we need to make parts list topic so people can look up the number so they can go to local part store
Old Jan 20, 2010 | 05:12 PM
gone4aRide's Avatar
Hey guys, thanks alot for the info. Those numbers really helped me out. I have a 98 Land Rover Discovery and i need to change the hubs. a friend of mine (who is a semi-mechanic) is going to do all the work for me. He already ordered the hubs from qeautoparts.com. The price was very low, luckily since I'm a college student and I dont have money to throw away! Anyways, If any of you guys are looking for hubs, bearings etc. try out this store qeautoparts.com. I recommend it for Land Rover parts. Good luck guys.
Old Jan 20, 2010 | 06:55 PM
JumPeR04's Avatar
I am broke to also kewl thanks for the site and it aint hard to do the hub or the whole truck.... It takes time and patience also thanks disco mike I will get on that this wkend
Old Jan 21, 2010 | 04:27 AM
antichrist's Avatar
I forgot to mention, for the hub seal get RTC3511, it's a better double lip seal (as used on Defenders) than the standard seal used on the Discos.
Old Jan 21, 2010 | 07:59 AM
JumPeR04's Avatar
Thanks again
