The rear height level control light came on and it went off after i restarted the car
Old 06-11-2009 | 09:10 AM
VikingDiesel's Avatar
Default The rear height level control light came on and it went off after i restarted the car
So the light came on yesterday that I have never seen before, its a pic of the land rover with (2) arrows in the back pointing to each other, it seems like its the Height Leveling control sensor or something like that, however, it went away after I restarted the car and hasn't come on since, any ideas? I don't think this has anything to do with the airbags,???
Old 06-11-2009 | 09:50 AM
This is nothing to worry about unless it happens more frequently, or stays on, then you need to get the SLS codes read.
Old 06-11-2009 | 10:05 AM
Urban Panzer's Avatar
Er, think there is some confusion here...........
The SLS light has 1 arrow not 2, the symbol with 2 arrows is the ACE warning light, but they face AWAY from each other.
You need to be clear exactly which one it was........
I suspect it was the ACE light, if its not on then there is no fault, to confirm which light it was, just simply switching on the ignition will enable to to see it again when it self checks.
Old 06-11-2009 | 10:11 AM
Doesnt ACE have to due with cornering and is in the front of the car?
Old 06-11-2009 | 10:13 AM
Its the light right next to the HILL DECENT light to the right of it. Kind of look like the rear airbag light but instead of the light showing a lifted DISCO with an arrow pointing up, this shows a leveled DISCO with the arrows both at each other. Its the leveling light, I feel its this sensor in the rear arms
Old 06-11-2009 | 10:15 AM
yes, it controls the body roll when conering, a SUPERB system that makes the D2 stand well above the competition of the same "era".
Its fitted to both the front AND back
Old 06-11-2009 | 10:19 AM
heres the dash, Which number ??
Old 06-11-2009 | 10:22 AM
#26 is the one which come on
Old 06-11-2009 | 10:31 AM
Ok 26 is the SLS warning lamp, but I still see NO arrows only 1 exclamation mark, which is why I was confused and got you to confirm.
The light comes on if the vehicle detects a "configuration" issue with the SLS, it may have been just a momentary "Glitch" in the height sensor / s reading, but has gone away.
it will also illuminate if the supply / battery voltage is less than 10 volts for more than 1 second, so it may have been that. the whole point is, if its not on now then dont worry about it, if it comes on and STAYS on, then check the voltage supply from the battery / charging system, if thats ok, then its a visit to get the codes read.
Old 06-11-2009 | 10:34 AM
no exclamation mark on mine, I have (2) arrows and it prob is the low voltage but i thought low voltage would have the S and M light that would flash
Quick Reply: The rear height level control light came on and it went off after i restarted the car
