Rear hub leak question
Doing the brakes and noticed a lot of crud inside the right rear rotor. Oil looks to be seeping from the area where the flange goes into the hub - this leads me to believe the hub seal is the culprit. The other 3 hubs are clean and dry.
Should I replace both rear hubs, or only the one that's leaking. Leaning towards only fixing what seems to be broke.
Advice?
Thanks in advance.
Advice?
Thanks in advance.
As a field technician on equipment... do both sides. As a DIY guy for myself... daily driver or wife's vehicle then do both. As a third vehicle, do the side that's leaking. Check axle for wear around sealing surface. Check axle vent. Use a hammer activated impact driver for the philips head stuff.
The genuine wheel bearings coming on the truck are well made & hearty. I would service the seal itself - the oil seal in rear is just a large O-ring & I would order a few at same time. they are cheap. This way you have one for other side and additional incase you reinstall and chaffe it going in.. ( I can say, a time or two I’ve reinstalled and knicked the seal pressing in hub & 2 days later notice that weep again. Frustrating but very achievable to get it right)
this way when you pull your wheel bearing, it will be separated from your drive axle & you can spin in your hand & feel how smooth it is. Essentially confirming Your suspicion the seal is your culprit & not your hub.. it Should spin silky smooth - if so; no reason at all to swap in my opinion. I have put many many highway and Offroad miles on my original hubs & Swapped for used OEM hubs Over new & run for 10’s of thousands of miles & counting.
If high miles - I was taught a trick to remove abs sensor & drop a tsp or so of lucas hub oil in there. Its like honey for your hub. (careful of the O-ring & ensure senser remains/wiped clean as reinstall)
