Rear (tail) door stock shut - catch 22
Old 01-01-2020 | 04:44 PM
PPorBust's Avatar
Default Rear (tail) door stock shut - catch 22
My rear door won't open.
The lock/unlock with fob works fine.
I tried using the inner door handle - no luck.
I removed rear door liner. All linkages are in place and (AFAICT) still work.
I tried manually moving the lever that is normally moved by exterior door handle. Still won't open.
I can't remove the actuator, b/c the GD door is stuck shut.
Any ideas?
Oh, and Happy New Year!
Old 01-01-2020 | 05:22 PM
PalmettoDisco's Avatar
A quick search on here would provide the answer, just look below (this thread) for related topics. Pop out the land rover emblem on rear exterior latch.There is a hole behind it giving access to latch mechanism. Spray a lubricant like wd-40 in there to free things up. That should do it.
Old 01-01-2020 | 05:27 PM
PPorBust's Avatar
Already BTDT. No luck.
Old 01-01-2020 | 06:15 PM
Oversized tire on back? Maybe bent hinges? Tried lifting up to open?
Old 01-01-2020 | 06:39 PM
markwemple's Avatar
When mine did that, I had to replace the whole actuator. Broke apart the old one carefully until I could manually open it up.
Old 01-01-2020 | 06:46 PM
No Doubt's Avatar
Same thing happened to me.
Standing outside my Disco behind the rear hatch, I shoved a screwdriver rearward of the release handle and pried it forward toward Driver's seat direction. Pulled out the screwdriver and the rear hatch then opened when I squeezed the release handle with my hand as if normal.
Sprayed penetrating oil fore and aft of that release handle.
Never popped the Land Rover plastic badge off.
Problem fixed (for me).
Happy New Year!
Maybe this fix will work for you, too.
SundayFunday (01-02-2020)
Old 01-02-2020 | 03:28 AM
PPorBust's Avatar
Normal sized spare. Door wasn't ever sagging or out of line before. Tried all sorts of lifting, jiggling, etc. Doesn't budge.
I'll look into the screwdriver trick- then see about taking it apart.
I've been binge watching "La Reina del Sur" in Spanish. Learning all sorts of new ways to swear...
Old 01-02-2020 | 07:30 PM
PPorBust's Avatar
Well, I crawled in the back and got the door open.
It was not the linkage or the exterior handle. The actuator assembly itself was stuck. I started disassembling it w/ a screwdriver, a fist, and some words of "encouragement". Before I reduced it to rubble it decided to let go.
Here is what I found:
Not hard to imagine why it wasn't in top form.
Here's where all that dirt came from:
That's the "seal" for the exterior door handle. Think I'm gonna have to do something about that....
The following 2 users liked this post by PPorBust:
No Doubt (01-02-2020), PalmettoDisco (01-03-2020)
Old 01-02-2020 | 07:58 PM
No Doubt's Avatar
Good work!
msm15
07-11-2020 01:30 AM
huggi
04-23-2018 10:45 AM
j.dstasio
09-10-2010 11:18 AM
CPDieker
09-25-2006 09:37 PM
StephenK1706
05-10-2005 01:34 PM
