Rebuilt Transmission won't shift into park to start Rover
I've got a 1975 Rover Series 3 109 with a rebuilt 4.6 liter Rover V8 and a rebuilt ZF automatic transmission. A few days ago when I arrived home I could not get it to shift into park. After shifting down and back up I got it into park. Today, the truck wont start but all of the appropriate dash light are on as if it is ready to start. When I wiggle the gear shift, it will sometimes kick as if it will start but then stops. I think the starter inhibitor switch is not working right and telling the computer its not in park, but not sure. Any ideas or other things I should check. Battery is good. Thanks.
Mine does this every so often. Indicator lights usually show that it's in park but it won't turn over. I'm pretty sure it's the XYZ switch being very slightly off adjustment.
I can usually solve it by whacking hard on the back of the shift lever to nudge it forward a fraction of a millimetre. It does sometimes require me to shift through the gears and back into park and a couple of key cycles.
Long-term fix will be to adjust the XYZ.
Thank you....I suspected it might be the XYZ. If whacking it won't work, can you please tell me what the XYZ looks like or attach a pic. I see its suposed to be on the side of the tranny but I am not sure I am looking at the right thing. First time dealing with this. Much appreciate the help and glad to now you hada similar issue.
Bill
Bill
The xyz is on the left side of the transmission, and can be accessed pretty easily without needing to lift the vehicle.
It looks like https://www.ebay.com/itm/224749631393
There are two bolts (pretty sure they are 10mm) that hold it in place; one is in a slot which means that the xyz can be rotated slightly. Have an assistant sit inside the truck with the ignition on but engine not running so you can read the displays, and then slowly move the xyz until all the lights light reliably and correctly when the lever is moved and returned to Park. Tighten the adjustment bolts and see whether or not the problem goes away.
Okay..well at least I know I am not totally crazy. Didn't know what the xyz looked like because I don't have one(first picture). I have traced the issue to a bad solenoid (second picture) and when i press it in completely with a screw driver, starts right up. Have any of you seen this set up before? The solenoid screws into the side of the gear shift and I can't seem to locate a serial number or brand on it. Choices online don't seem to have the screw section I need. Any advice on where to find one much appreciated. I will take it to a couple local shops and see if I can find one. Thanks for the help!
Its the solenoid with the two wires that appears to be dead
No xyz!! Its the solenoid with the two wires that appears to be dead
