Recommended Parts thread
This is a list of all compatible and/or preferred parts for the Land Rover Discovery II.
NOTE: This is a listing of parts and not a listing of where to buy. Any links to online stores are just for reference only and do not necessarily represent the best place or lowest price to purchase.
If you know of a part that is not on this list, please post below with part# and any additional info, and I'll add it to the top post categories.
AIR AND FUEL DELIVERY
BRAKE SYSTEMS
CHASSIS AND SUSPENSION
COOLING AND HEATING
Thermostat -OE Type
Water Pump - BPUtah - Part# STC4378X (Gasket Part# ERR4077)
DRIVETRAIN
ENGINES AND COMPONENTS
Heads
EXHAUST
Bosch Oxygen Sensor - Amazon - Part # 15175
FITTINGS AND HOSES
GASKETS AND SEALS
GAUGES
IGNITION AND ELECTRICAL
Plug Wires
INTERIOR
OILS/FLUIDS/SEALER
Oil Filters
WHEELS AND TIRES
BRAKE SYSTEMS
COOLING AND HEATING
Thermostat -OE Type
- Thermostat (180f) - BPUtah - Part# PEL500110 (Should be grey in color, soft spring)
- Motorad (180f) - Amazon - Part# 439-180
DRIVETRAIN
Heads
- Head Stud Kit - ARP - Part# 157-4301
- Head Stretch Bolt kit - Atlantic British - Part# 9224a (same as OE part # ERR2943)
EXHAUST
FITTINGS AND HOSES
GASKETS AND SEALS
GAUGES
Plug Wires
- STI Plug Wires - BPUtah - Part# RCIWS721
- Kingsborne Plug Wires - Kingsbourne - Part# IGN 790
INTERIOR
OILS/FLUIDS/SEALER
Oil Filters
- K&N 3001
- Mobil 1-301
- Purolator L30001
- Purolator L40316
- Wix 51515
WHEELS AND TIRES
ARP-bolts.com | The Official Site of Automotive Racing Products, Inc.
I believe someone said Justin at lucky 8 had a good price #124 4003
you can always sell the head bolt kit on ebay and go with studs, someone here might buy them.
it would be nice if there was a cross over chart for say plugs, oil filter and items like that,
Water Pump: STC4378X
180F Thermostat: PEL500110
STI Wires: RCIWS721
All part #s are from British Parts of Utah which is the best place I've found to buy these particular parts. Only caveat is on the wires...I use Taylor Spiro Pro Universal, which are also 8mm silicon, 45 deg boot. You'll have to cut/crimp these but will save $15-20 and they're just as good. More importantly, they're probably on the shelf at your local parts store.
STI Wires: RCIWS721
