Reinforce Roof to Up Load Limit
Has anyone here ever reinforced their roof to increase the load limit? I don’t want to reinvent the wheel if this has already been done well. Some searches online haven’t shown much fruit.
I imagine running thick, wide steel bars along the interior ceiling at six inch intervals (or something like that), attached to thick steel pillars on the side. Maybe even running a steel mesh along the interior ceiling in between these bars and then plastering the mesh with… I don’t know, welding is my weak point, but some sort of metal equivalent of plaster? Is this even remotely in the realm of possibility or sanity?
Don’t the gutter mounts determine the weight limit of the roof rack, since it’s tied into them?
Actually, for that matter, what IS the load limit if you have a roof rack? The poundage mentioned in the manual is strictly for the roof rails I think. And obviously tipping and center of gravity are legitimate concerns but I’m focusing on load weight limits here, with a roof rack attached to gutter rails.
Whoa, 500 pounds, that is impressive. I have long wondered how roof top tents could work safely if maximum loads were supposed to be in the low 100 pounds, but I misunderstood that was a roof weight limit and not roofrack. Those are some strong gutter rails. In my other Disco in Africa there’s a basket roof rack on top, tied to the gutter rails, and I’ve crawled around up top with some heavy loads, but probably max 250lb total weight at one time.
So the bigger concern seems to be center of gravity rather than weight.
