Remove vacuum line on intake
Old Nov 6, 2008 | 05:10 PM
searanch's Avatar
3rd Gear
Default Remove vacuum line on intake
Hopefully someone can help me in removing the vacuum line to the brake booster from the upper intake manifold. It has a little red ring which feeds into the intake. I don't want to force it and break it. Once I get it out I should be able to remove the intake and complete the installation of new spark plug wires and valve cover gaskets.
I would really appreciate any help.
02 Discovery II
Martin
Old Nov 6, 2008 | 05:26 PM
Default RE: Remove vacuum line on intake
Replace the wires with out removing the intake, do you have secondary air, an emission device?
Old Nov 6, 2008 | 05:34 PM
Disco2Guy's Avatar
It's a push or pull release I think. I looked real quick in the RAVE but didn't see anything.
searanch's Avatar
3rd Gear
I do not have secondary air. I do however need to replace the valve cover gaskets which requires I remove the upper intake. I need to remove the brake booster vacuum line at the upper intake. It has a red ring and I don't want to force it.
Appreciate any help...
Old Nov 6, 2008 | 05:58 PM
jkid's Avatar
Mine pops out real easy. I think you just push in the red ring and pull the hose out. Don't force it because I'm not positive.
Old Nov 6, 2008 | 06:06 PM
Disco2Guy's Avatar
I found it in the RAVE (30-2-17). It just says to disconnect the line, but no instructions on how.
Old Nov 6, 2008 | 11:08 PM
searanch's Avatar
3rd Gear
ORIGINAL: jkid
Jaysus that's exactly how it comes out. Counter-intuitive for an Irishman who goes thru life pullin' on ****. Thanks man...
Martin
Old Nov 22, 2011 | 11:49 AM
tshah209's Avatar
Default Red ring
I was doing the sea foam cleaning for my 2000 disco II. After trying to snap the red ring back in, a peace snapped off. Now the vacuum tube is not air tight. Anybody know where I can get a replacement for the red ring? I went to the dealer and they said I had to replace a whole segment for $300 plus!!!
Thanks!
Old Nov 22, 2011 | 12:38 PM
drowssap's Avatar
I had the same type of problem on one of my other vehicles what i did was tap the manifold and installed a brass ****** fitting that you can get a HD and just push the vacuum line over the barbs and it locks in place. hope it helps, a lot cheaper than $300 too.
Old Nov 22, 2011 | 05:54 PM
jafir's Avatar
http://www.roverparts.com/Parts/LZN100220LG.cfm
Charlie_V
Jan 18, 2014 09:53 AM
izi6969
Freelander
Oct 23, 2012 10:16 AM
bigbenny
Jan 8, 2012 02:59 PM
dammad
May 8, 2007 12:22 PM
