-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Replace Cam & Lifters?? (https://landroverforums.com/forum/discovery-ii-18/replace-cam-lifters-51555/)
Thekid 07-27-2012 12:08 PM
I recently picked up an '02 DII with a blown engine (shot rod through block).
I have a replacement low mileage replacement long block ('00 with only 90k on it). I have had the heads gone through and I have read the sticky about rebuilding the engine.
My main question is should I replace the cam & lifters from this replacement long block? It was a known good engine and with 90k on it does it warrant it? I'm not against spending another $500 but if it's not warranted then I won't.
Savannah Buzz 07-27-2012 12:12 PM
IMHO you will have enough other things to spend money on. You are just getting warmed up. Be sure to do oil PSI manual gauge test.
jafir 07-27-2012 12:48 PM
Since the heads are off anyway, you might be able to pull the lifters and look at the camshaft to see if it needs replacement. They are a pretty common wear item on rover v8's so I hear....
But so are a lot of other things. How far do you want to go?
Thekid 07-27-2012 01:26 PM
How far do you want to go .... that is the Million $$ question that I'm trying to figure out.
The bottom end was solid, which is why I got it, so I'm just trying to figure out far to take it. Unless there is a known issue with cam/lifters I'd rather save my $$. At the same time, I don't want to go through all this work only to regret it in a few months.
As for the oil PSI test I had plans to just replace the oil pump anyway. Is this something I should reconsider if the PSI tests ok?
Savannah Buzz 07-27-2012 02:47 PM
If you are doing the pump (good idea), still do PSI test afterward. While in there, think about the timing chain. Inspect water pump while off.
Disco Mike 07-27-2012 03:03 PM
After reading the sticky, inspect each lifter and lobe per the direction, that will tell you where you stand.
Make sure you throw a new rear main seal on the engine and a front tranny seal if there are any leak indications.
RoverMasterTech 07-27-2012 04:13 PM
While the motor is out mayswell do all new bearings, crusifix seals, rear main seal and oil pump.
the stuff is cheap and you will have a "like new" motor. If the cam is fine i'd just put new lifters on it. The cam does not "wear out", the hard surface of the cam grinds off due to lubrication issues (low oil pressure, thin oil, low zinc/molly oil) and a lobe goes round in about 100 miles.
Thekid 07-27-2012 05:11 PM
What would be the intent of doing all bearings? If the oiling issue was not a problem, to warrant a cam as you suggest, then why would the bearings be suspect?
Additionally, all "old school" rules say that if you replace cam/lifters as a set. Why would that theory not be followed here?
I understand all of the seals and am planning on that as well.
Savannah Buzz 07-27-2012 06:20 PM
Maybe pin liners as well
Spike555 07-27-2012 09:19 PM
I'd just leave well enough alone.
Get her running and use the money you saved and take your family for a weekend trip in the Rover.
