Replace Cam & Lifters??
Old Jul 27, 2012 | 12:08 PM
Thekid's Avatar
Default Replace Cam & Lifters??
I recently picked up an '02 DII with a blown engine (shot rod through block).
I have a replacement low mileage replacement long block ('00 with only 90k on it). I have had the heads gone through and I have read the sticky about rebuilding the engine.
My main question is should I replace the cam & lifters from this replacement long block? It was a known good engine and with 90k on it does it warrant it? I'm not against spending another $500 but if it's not warranted then I won't.
Old Jul 27, 2012 | 12:12 PM
IMHO you will have enough other things to spend money on. You are just getting warmed up. Be sure to do oil PSI manual gauge test.
Old Jul 27, 2012 | 12:48 PM
jafir's Avatar
Since the heads are off anyway, you might be able to pull the lifters and look at the camshaft to see if it needs replacement. They are a pretty common wear item on rover v8's so I hear....
But so are a lot of other things. How far do you want to go?
Old Jul 27, 2012 | 01:26 PM
Thekid's Avatar
How far do you want to go .... that is the Million $$ question that I'm trying to figure out.
The bottom end was solid, which is why I got it, so I'm just trying to figure out far to take it. Unless there is a known issue with cam/lifters I'd rather save my $$. At the same time, I don't want to go through all this work only to regret it in a few months.
As for the oil PSI test I had plans to just replace the oil pump anyway. Is this something I should reconsider if the PSI tests ok?
Old Jul 27, 2012 | 02:47 PM
If you are doing the pump (good idea), still do PSI test afterward. While in there, think about the timing chain. Inspect water pump while off.
Old Jul 27, 2012 | 03:03 PM
After reading the sticky, inspect each lifter and lobe per the direction, that will tell you where you stand.
Make sure you throw a new rear main seal on the engine and a front tranny seal if there are any leak indications.
Old Jul 27, 2012 | 04:13 PM
RoverMasterTech's Avatar
While the motor is out mayswell do all new bearings, crusifix seals, rear main seal and oil pump.
the stuff is cheap and you will have a "like new" motor. If the cam is fine i'd just put new lifters on it. The cam does not "wear out", the hard surface of the cam grinds off due to lubrication issues (low oil pressure, thin oil, low zinc/molly oil) and a lobe goes round in about 100 miles.
Old Jul 27, 2012 | 05:11 PM
Thekid's Avatar
What would be the intent of doing all bearings? If the oiling issue was not a problem, to warrant a cam as you suggest, then why would the bearings be suspect?
Additionally, all "old school" rules say that if you replace cam/lifters as a set. Why would that theory not be followed here?
I understand all of the seals and am planning on that as well.
Old Jul 27, 2012 | 06:20 PM
Maybe pin liners as well
Old Jul 27, 2012 | 09:19 PM
I'd just leave well enough alone.
Get her running and use the money you saved and take your family for a weekend trip in the Rover.
