Originally Posted by CollieRover
(Post 606837)
Have you considered an LS Swap? There is a shop in Ohio doing them. I like the 4.6, but an LS would be sweet.
https://landroverforums.com/forum/di...ne-swap-82431/ |
(Post 606837)
Originally Posted by dtmbinb
(Post 606853)
I didn't really consider that. I can get the long block from Turner in about a week or so, and the Rover specific indie shop I use can get the swap done as soon as the motor arrives. I didn't even consider shipping the Disco out of state. From everything I've read, the Turner motor should cure all the problems with the stock 4.6. The cam and flowed heads should give it a little bit better drivability. My Disco should be pretty well sorted after this. My interior is excellent, including a custom black headliner and new shift / brake boots. Paint and body is great. It's Chawton white with Tundra grey interior....not many like it that I've seen. If it wasn't a keeper before, it sure as hell is now!
Well, Turner long block with Kent cam and gas flowed heads is ordered. Ordered all new hoses, radiator, reservoir with cap, gaskets, water pump, front cover, coils, plugs, wires, motor mounts, sensors, belt, pulleys, tensioner, etc. $1100 in parts to accompany the new engine. Should have a reliable truck back on the road in a few weeks. If I have to do anything other than fluid changes or brakes over the next 60,000 miles, I'll be very surprised. This fiasco with the cracked block has set me back around $10k. I plan on keeping the Disco long term, so I figured I'd do a proper refurb. I'll keep my progress and results updated....
(Post 607670)
(Post 607670)
Definitely need some engine porn from this fiasco. Sorry you ended up taking the hit, but hopefully it get shinier from here on out.
I am mostly excited to hear about those gas flowed cylinder heads.
I'm getting excited for this project. I really hope it goes smoothly. I can't wait to fire up the new engine!
(Post 607781)
| All times are GMT -5. The time now is 10:18 AM. |
