Road Trip ready?
Old 06-02-2011, 12:25 AM
LRDiscoII1974's Avatar
3rd Gear
Default Road Trip ready?
Hey everyone. I am BRAND new here..so don't hate. haha. But, I just wanted to get some opinions from you guys. I have a Disco II that I want to take on a road trip to FL. I live near Atlanta, so it isn't that far. I have had a major engine tune up recently, and am planning on replacing the U joints before I leave. Also, I have a slow leak in the left head which I am not worried about quite yet. It does burn a little oil..but then again..what LR doesn't? I was just planning on brining a quart or two of oil with me just in case. I am also getting the trans.case filled before I leave as well. What are your thoughts? Any helpful advice would be appreciated
Old 06-02-2011, 01:11 AM
Frank4's Avatar
Roll the dice man.
Old 06-02-2011, 05:33 AM
drowssap's Avatar
I have a slow leak in the left head which I am not worried about quite yet.??????????
Old 06-02-2011, 07:00 AM
DarylJ's Avatar
Say what now? If you are talking about a coolant leak you shouldn't be taking it anywhere. If you're talking about a rocker cover gasket, then sure....whatever. As long as it isn't gushing.
Mine. That's not unique. They don't have to burn oil if they've been serviced properly, especially considering how frequently most of them have had head gaskets done (so the heads are already off and you can do the valve guide seals).
Tow another car behind you.
Old 06-02-2011, 08:08 AM
So, how many miles on the truck?
I would suggest that because you just bought the truck that you do the major service that I have posted at the top of this section, all of it including rebuilding/replacing the front drive shaft before it takes out your tranny.
Old 06-02-2011, 08:54 AM
as long as you do the drive shaft like you said you were going to you should be fine. just bring oil and coolant with you.
Old 06-02-2011, 09:56 AM
sloan74's Avatar
yeah definitely do that drive shaft before driving it that far. That's a lot of hot interstate travel and if those joints bind up and explode that shaft, at that speed your tranny is done as Mike said.
leak as in valve cover (rocker cover) seepage? or do you mean actual leak, as in oil dripping into your driveway?
Old 06-02-2011, 10:34 AM
yloDiscoII's Avatar
Also, I have a slow leak in the left head which I am not worried about quite yet.....
Yikes, those are famous last words, brosef.
Get that leak figured out or you'll be sorry..............I'm super serial.
Old 06-02-2011, 10:51 AM
thospb's Avatar
If you do Mike's Service then you will know that you HAVE fluid everywhere and what kind you have. Since you just bought the vehicle, a road trip is no time to find out there is no fluid in a differential.
Old 06-02-2011, 10:56 AM
3rd Gear
There is no fluid on my driveway, and plenty of coolant in the system. I am getting the U joints done right before I leave. I am concerned about the left heads. Sad part is, the previous owner had just recently replaced all the head gaskets..so I don't know if it is actually leaking, or just remnants from when it was (maybe someone could enlighten me as to if this is possible). I just know it is either burning or leaking oil because I check the dipstick periodically and add a little oil when it is starting to get lower. I was planning on bringing a quart with me, just in case. Thanks for the help guys
Quick Reply: Road Trip ready?
