..:: The rocker assembly cleaning situation ::..
#21
#23
Try using CRC Throttle Body Cleaner (#05078) from Auto Zone, Advance, etc. You will be amazed how well it works and burns off with NO run issues. Looks like this >
#24
...thanks DROWSSAP! ...since I was putting everything back together, I temporarily solved it by using those tie wraps that you secure with a screw, but will look into the ones you mention from Kingsborne, definitely want them to be better and nicely secured. ;-]#
#25
...thanks for your response DiscoBuckeye, but if I squeeze and push hard enough they do go in; I prefer getting something less problematic for these 8mm wires "than a fat man in the eye of a needle", as Sting would sing; besides, a couple are broken, so it would be the best option to get the right ones! ;-]#
#26
#27
Try using CRC Throttle Body Cleaner (#05078) from Auto Zone, Advance, etc. You will be amazed how well it works and burns off with NO run issues. Looks like this > Amazon.com: CRC 05078 Throttle Body and Air-Intake Cleaner - 12 Wt Oz.: Automotive
#28
#29
...here the pics of how they now are secured!
...here you can clearly see what type of Tie Wraps I used.
...here you cannot see the screw, but it's down there!
...here you can see how it was secured with the same bolt that held the original separator in place.
#30
..:: UPDATE ::..
...glad to report that my truck came to life without major issues so far. Had a minor electrical issue that was resolved by "resetting-it", I guess is just like a phone that received a "major update", go figure!
So cleaning process seems to have done good, truck sounds nice and serene, didn't test drive further cuz was night and had a minor leak by the inlet Heater Matrix hose, hopefully is not fully in or clamped incorrectly, will check and report back soon, thanks everyone.
Future posts on different jobs are on the dock! ;-]#
