Rocker Cover Bolts???
Old 12-22-2008, 11:52 AM
jycsalas's Avatar
Default Rocker Cover Bolts???
Hello All,
I'm leaking oil around the rocker cover gaskets and i want to tighten them but...... the bolts on my 03 are 12point. I don't have a 12 point small enough to fit on the bolts so I'm trying to find it online as the 5 hardware stores on this island don't have what I need. What size are they and what socket do you guys use?
Thanks
Old 12-22-2008, 01:54 PM
Default RE: Rocker Cover Bolts???
Most 1/4" socket sets have a socket that will fit. Make sure not to over tighten the bolts, 6 foot pounds is what the factory sets them at I think 12 is better, they won't vibrate loose so easy.
Old 12-22-2008, 08:57 PM
I went to Sears and bought my 12pt 8mm socket for mt 1/4" rachet for $4.
I think by using a 1/4" drive you cant over tighten them.
Old 12-22-2008, 09:07 PM
sloppyjoe's Avatar
are you sure the gaskets are not toast?
Old 12-22-2008, 09:14 PM
Sloppy, sloppy, sloppy...this is standard Rover leakage. For some odd ball reason the bolts that hold the rocker covers on vibrate loose over time and then the valve covers start to leak.
Next time you go to Sears pick up a 12pt 8mm 1/4" drive socket.
Replacing the valve cover gaskets is a job and a half.
Old 12-22-2008, 09:21 PM
sloppyjoe's Avatar
ORIGINAL: Spike555
one day you and i will have a clasic peter/chicken brawl,,,,,,
biatch!!!!
Old 12-22-2008, 09:25 PM
It's not my fault you gave me a expired coupon.
Old 12-22-2008, 09:28 PM
sloppyjoe's Avatar
ORIGINAL: Spike555
have you seen the second fight?
Old 12-23-2008, 07:48 AM
jycsalas's Avatar
lol.... Peter / chicken brawl...
Anyway, I knew it was a 12point 1/4 drive socket but i couldn't figure out if it was a 8mm or 9mm. I have found 12 peacc sets on ebay that include this size so i may have to go with that!!
Thanks!
Old 12-23-2008, 01:30 PM
rinmud's Avatar
8 mm and buy new bolts from the dealer becuase they are pre treated with lock tight and a seal at the neck, cheap 2 bucks apiece scott
Quick Reply: Rocker Cover Bolts???
