Roof leak
I've been chasing leaks on my 03.
Had a windscreen leak which was solved when I had the windscreen replaced and sealed much better.
Had sunroof leaks. Sealed them and disconnected the switches.
Had some minor rear leaks. Did new sealant on the alpine windows and fixed that.
Had an other leak that would get the front passenger seat belt wet and the headliner above it wet. Sealed the gutter to solve that.
I also put new sealant around the roof rails just in case.
We have recently had really hard rain and no water ingress.
so guys is it possible the water is coming in through there? Is that spot supposed to be sealed? As you can see , I had put some clear caulking to seal up the windshield edge.
