Rotating tires
I bought a 2000 Discovery II two weeks ago. The front tires are pretty new. I am buying two identical tires this weekend. Should I rotate the older tires to the rear, or leave them on the front. Which axel gets more wear or is there a diffrence?
They all need to be the same size. I would replace all 4 at the same time and keep them rotated. Having the front or rear spin faster will load you transfer case. It would be like running 2 different sizes on the left and right. That said, it doesn't matter which axle you put them on (if they are really close). Just keep them rotated.
dustinvonholten
Nov 23, 2010 05:08 PM
