Rotella or Royal Purple?
Old Oct 22, 2012 | 02:25 PM
  #21
ZGPhoto's Avatar
Originally Posted by binvanna
I am fully bought into synthetics, meaning I believe they are significantly superior and I use them. I am not an Amsoil televangelist though. I never bought that hype. With an older engine with a lot of varnish and some sludge, short change intervals is more important than maintaining viscosity, lubricity etc. for long intervals. I want to drain the contaminants while they're in suspension and get them out of the engine before they come out of suspension and form more deposits. The contaminants do not come from the oil itself breaking down. They come primarily from blow-by and wearing surfaces. I also get a lot of condensation and other stuff from short drives.
Since the most important thing for me in my Rover engine is moving the contaminants suspended in the oil -out-, that means throwing a lot of oil away! (short change intervals) Because of that I don't bother using expensive synthetics. I do sometimes use Mobil 1 because the 5 qt jugs can be fairly inexpensive when on sale.
Yeah I'm not saying it's the best kind of mousetrap out there, just that it gets the job done and I don't have to worry about anything with it.
Old Oct 22, 2012 | 04:11 PM
  #22
lr2001silver's Avatar
Banned
Rotella & Mobile1-301 is what I use and have for a long time and never had any problems but I also change all the fluid when or before its supposed to be changed.
Old Oct 22, 2012 | 04:34 PM
  #23
Dave03S's Avatar
In addition to being "sold on" the use of synthetic oil, you should research the application for which you are using it.
Synthetics are made for modern tight tolerance engines that tend to last hundreds of thousands of miles,
Rovers have a 50+ year old Buick flat tappet Pushrod V8 design.
Synthetics may well be fabulous for your BMW, Corvette, DOHC Acura, etc...
Putting them in a 10 to 15 year old vehicle with a 50 year old motor design is a whole other story.
I got to buy a new camshaft and lifters (along with a lot of other parts since the thing was apart) largely because an LR Dealer broke in my new 4.6 (in 2007) with synthetic 5w30. At the time I questioned this, but I had just bought the truck and took their word for it. It took 4 years and 42k (end of extended warrantee) to destruct using that oil w/ all service done by same dealer.
That was before I learned about LR Dealer Service Departments and how LRNA supports the decistions they make. (not)
Old Oct 22, 2012 | 04:59 PM
  #24
Banned
So how does a guy preach that he is "sold" on synthetic oil and then turn around and say that he would not use it in his truck? Does not make much sense to me.
Old Oct 22, 2012 | 05:04 PM
  #25
Dave03S's Avatar
If he knows the difference between a new Corvette engine and a Disco engine. Thats how.
Old Oct 22, 2012 | 05:15 PM
  #26
ZGPhoto's Avatar
Fat chicks and skinny chicks like cake all the same man...
Old Oct 22, 2012 | 07:19 PM
  #27
jneil's Avatar
Syn oil is great stuff, but its not that great. I spent a lot of cash on sun oil and it turned into crud anyway,changing oil often is the key. Use syn if you like,it doesn't hurt, it's just cost more.
Old Oct 22, 2012 | 08:04 PM
  #28
Originally Posted by TRIARII
So there's only 5 more weeks left until my 2004 Discovery SE is paid off and I'll get the title and keys. First thing on my to-do list is premium oil and filter change. I was using Shell Rotella oil with my former D1, but with high mileage and poor mechanical condition from the start I could not determine any benifits of Rotella. Nevertheless I'm going with either Rotella or Royal Purple engine oil for my 2004. Which is better? Which will do more for my 4.6 engine? Price is not a concern when it comes to oil so fill me in on what you think is better and why.
Ok, here is the low down on your question, you know I've never lied to you Julian.
IF you use Royal Purple use their 15w-40, use the larger Mobil 1 oil filter and change the oil every 15,000 miles or once a year.
IF you use the Rotella use a standard oil filter, like from NAPA and change the oil every 5,000 miles no matter the time.
Royal Purple is good for at least 15,000, the limiting factor is the oil filter, the Mobil 1 oil filter is good for 15,000 miles.
Rotella, in our engines, for the normal driver, is good for close to 10,000 miles, it is almost as good as a full synthetic, remember more over the road trucks use Rotella than any other oil and they go 1million+ miles before needing a rebuild.
However I would still recommend 5,000 mile oil change intervals.
The more expensive oil filters are a waste of money unless you are going over 10,000 miles between oil changes.
They do NOT tramp more dirt, they only HOLD more dirt, there IS a difference.
There is a huge cost vs benefit factor you need to think about, changing a oil like Royal Purple to often is a absolute and complete waste of time and money.
The 3,000 mile oil change interval was put in place 50 years ago by people who make money off of oil changes, the oil companies and the shops that do the oil changes.
The 100% correct way to know when to change your oil would be to have a oil analysis done, then the lab could tell you "change it every X,XXX miles as long as you use this oil and filter combo"
I use standard sized oil filters, Shell Rotella, change it every 5,000 miles and I dont worry about it.
For the first 152,change of my trucks life the oil was changed every 7-8,000 miles at the dealer, I switched it to 5,000 miles, almost 220k and still going strong.
Its just a truck, it will last as long as it lasts no matter what you do.
www.bobistheoilguy.com for more than you ever wanted to know about motor oil and motor oil filters.
Old Oct 22, 2012 | 08:57 PM
  #29
grandkodiak's Avatar
Flat Tappet Cam Tech - How to Prevent and Fix Cam and Lifter Failure - Hot Rod Magazine
Rotella, for high zinc, cheap price and decades of field proven reliability.
If I ran standard oil, I'd use a zinc additive. I wouldn't be especially "worried" about using synthetic either. They are supposed to be highly resiliant in resisting high pressure situations that are posed by flat tappets. I'm sure they do more then plenty for bearings and everything else that dyno oils been doing by itself since the industrial revolution.
3,000 miles, 5,000 miles, 15,000 miles..... not NEARLY as important as the temperature and oil grade. 3,000 miles in a 10 mile daily commute, a weekend 4 mile trail crawl, and a 1,500 mile a week big rig run are completly different. I live in NJ, less then 3k a YEAR, so I change the oil roughly 3 times a year, switching to from 15 to 5 only around december, since overnights tend to go around or below freezing from then until roughly march depending on the year. I also have a slow leak, (or several haha) so I end up putting a half quart or quart of fresh new oil in every once in awhile between filter changes.
Going easy on the gas pedal will probably have far more effect on engine life then the oil company you choose... I rarely see above 2k rpm around town, 3.5k is the highest shell see merging on the highway if someones commin up behind me quick. saves me alot of wear and tear in the long run, saves me a good amount of gas, and i cant remember the last time i had to change pads/rotors on anything i've owned other then to upgrade them for ****s n giggles.
Old Oct 22, 2012 | 09:11 PM
  #30
The only problem with adding zinc is when it gets past the rings and valve seals and into the exhaust it WILL clog the catalytic converter and ruin it, thats why they have reduced the amount of zinc and phosphorus in modern motor oils.
It also ruins the O2 sensor's.
