Rotoflex - Necessity of Centering Bearing Replacement
Hi all,
I've done some searching through the forums but wanted to dedicate a post to try and capture some feedback on a specific nuance of the rotoflex replacement process: the centering bearing replacement. I'm chasing a minor drivetrain vibration that presents itself around 75mph and I'm thinking that the rotoflex is a likely culprit. Looking at the replacement process, I'd much prefer to just swap out the rubber piece itself rather than removing the driveshaft and popping out the centering bearing.
We're all aware that the rotoflex itself is a weak point and can fail. How often does this coincide with a centering bearing failure and how do you determine whether the bearing needs to be replaced?
Thanks!
Thanks!
![](https://cimg4.ibsrv.net/gimg/landroverforums.com-vbulletin/920x2000/1a03f1a7_20e5_498a_bbf8_db839dbf4133_bc344fba66b11e8d763acdd4813c159a2c9d4e92.jpeg)
Thanks for the responses, all.
My front driveshaft is only about 6 months old. When I first purchased the car, I had what a more substantial drivetrain vibration that started earlier, and it seemed to get worse at 75. After changing the front driveshaft, the bad vibration went away, and the secondary one remained - this is why I'm thinking it's the rotoflex, though I suppose it could also be unbalanced tires or maybe the front shaft was never properly balanced from Lucky8.
Since the Rotoflex is a relatively easy swap and has an unknown service history, I think it makes sense to start there before throwing $300 at a new front driveshaft.
First, the part in question is a bushing, not a bearing, right?
What is it's function? How would it wear out?
I understand that other bushings, mostly rubber, deteriorate and wear out (radius arms, Watts linkage, panhard rod), but this one is apparently made of steel and I don't understand from the diagrams how it could wear out.
If I were replacing the Rotoflex on my truck I would it ask myself those two questions and unless there was a clear reason to replace I'd leave it alone. But I understand I may be missing something so I look forward to hearing from others if they have more informed responses.
