Running hot?
Running hot?
we bought this truck about 3 months ago and have been doing some work on her since then. as to the cooling system, have switched to the genuine LR 180 t/stat and as of this past weekend have changed all of the cooling system hoses and have burped the Disco Lady about a million times. so, now we have a truck running in the 180's and 190's around town w/o the a/c on- pretty good. however, turn the a/c on and temp's like to get up to 210-212 in stop-and-go, but will go to the low 200's when moving. seems a bit high, thoughts?...
Are your electric fans running? They should come on with the AC as described below (from RAVE): Engine cooling fan control
While the A/C system is on, operation of the electric engine cooling fan, to assist refrigerant condenser operation, is determined by a combination of vehicle speed and external air temperature. When cooling fan operation is required, the ATC ECU outputs a cooling fan request to the ECM, which then energises the cooling fan relay. The cooling fan
request is output if vehicle speed is 80 km/h or less while the external air temperature is 28 °C (82 °F) or more. The
request is cancelled, and the cooling fan switched off, if either the vehicle speed increases to 100 km/h, or the external
air temperature decreases to 25 °C (77 °F).
Doesn't sound too bad. Last year when I had the OEM t-stat (190? 195?) My temps running 70mph with the A/C on were at 198 and it was 85 degrees outside. I just recently put in the 180 t-stat but it hasn't got warm enough yet for me to run the A/C.
thanks guys. dusty- no temp drop with increased rev's. ambient temp around 80, south florida (aka-flatistan). taking her on a road trip at the end of next month and really would like to get any cooling issues looked after. she will do a great job of 180's-190's in traffic w/o the a/c, but get that a/c going and it's 210-212, just seems odd that there'd be that much temp difference with the a/c on.
