SAI tubing alternative/mod
Old 08-28-2020, 07:22 AM
JUKE179r's Avatar
Lightbulb SAI tubing alternative/mod
Big thanks to @Extinct for the help on this project!
Here are some measurements and pictures of the SAI tube mod which makes it easy to remove and reinstall now...
51” (130cm) total length x 3/4” (19mm) ID hose then cut to...
12” (31cm) from SAI pump connector to T fitting
7” (18cm) T fitting to RH valve
32” (81cm) T fitting to LH valve
6x 1” (25mm) clamps
1x 3/4“ (19mm) T fitting
This is the oil catch can kit I bought from a UK eBay seller... https://www.ebay.co.uk/itm/223064881865
I've been running this for a week now at 60 degree ambient temps and it has been working very well.
I would caution though... with the extreme engine heat under the hood, it is making the flimsy hoses I purchased very hot and spongy/pliable. I might later switch to a thicker walled 3/4” (19mm) ID red HPS silicone radiator hose.
I was concerned there wouldn’t be enough SAI pump air pressure to get to the LH SAI control valve since I didn’t "T" it off directly in-between the two SAI control valves. Surprisingly there was plenty of air pressure going to both control valves. You can turn on the SAI pump briefly and test for air leaks by removing relay R6 in the engine bay and jumping the contacts with an insulated wire.
I hope this helps...
The following 4 users liked this post by JUKE179r:
acg (01-14-2021), Richard Gallant (08-28-2020), The Deputy (01-14-2021), The_OGCJR (07-15-2022)
Old 08-28-2020, 09:08 AM
keninnc's Avatar
Nice mod...
Biggest advantage I see is not having to line up those 2 holes in the bracket that line up with the coil pack. This would make it much easier when putting the upper manifold back on.
I'm wondering if you did this mod would relocating the coils be obsolete? May be able to change the spark plug wires with no issues without having those metal pipes and their bracket in the way.
JUKE179r (08-29-2020)
Old 08-28-2020, 12:51 PM
Received 1,148 Likes on 794 Posts
Thanks for the write up
JUKE179r (07-15-2022)
Old 08-28-2020, 03:00 PM
Extinct's Avatar
Received 1,460 Likes on 1,036 Posts
Originally Posted by keninnc
Nice mod...
Still not obsolete, it is an absolute bitch to get the coil packs and wires out from behind the engine. Stay tuned, I have a slightly different take on the coil pack relocation mod coming soon, much easier than what is available now.
The following 2 users liked this post by Extinct:
jastutte (08-28-2020), JUKE179r (08-29-2020)
Old 08-28-2020, 04:06 PM
Best4x4's Avatar
Received 2,272 Likes on 1,676 Posts
Yeah I've used 3/4 hose to replace the OEM hose which connects to the pump for years. Works great so I see no problem ditching the OEM metal line for hose. Good work!
Old 08-29-2020, 09:07 AM
dparham's Avatar
Very nice! I have a cracks SAI tube i had to tape up and plan to do at least the end run liek this.. the rest seem ok!
Old 08-31-2020, 03:55 AM
JUKE179r's Avatar
Thanks Guys!
UPDATE... I've been driving around now for over a week with the SAI rubber tubing. The SAI pump turns on and off as usual on initial engine start but now I'm noticing the SAI pump comes on after I stop at red lights for more than a minute. As soon as I hit the gas, the pump stops. I'm guessing it only happens while in "Drive" and the brake is applied. When I sit at idle in "Park" the SAI pump doesn't turn on except for during initial engine start. I've never noticed that happening before so I don't know if it started when I swapped to the rubber tubing or not.
I keep checking the Nanocom and I have zero fault codes for anything.... knock on wood.
Old 08-31-2020, 09:44 AM
jastutte's Avatar
Originally Posted by JUKE179r
Thanks Guys!
i have this happen on my '04. there doesn't really seem to be any rhyme or reason to it and no codes, so i've never worried too much about it.
Old 09-02-2020, 07:50 AM
JUKE179r's Avatar
That's good to know. Thanks @jastutte .
Old 01-14-2021, 05:17 PM
dparham's Avatar
6x 1” (25mm) clamps
How Did you get the connector off of the old hose? I lost a thread that explained it a while back... mine has completely crumbled away/. the plastic hose to the pump but connector on pump looks good...
Quick Reply: SAI tubing alternative/mod
