Say it aint so!!!!!!
I just got an 03 discovery a week ago and I am noticing that there is white smoke coming from the exhaust at start up and until it heats up. THEN I noticed that there was some fluid on the ground under it after running it. SOOOOOO I got a paper towel and soaked some up to see the color and it appears to be a pinkish color. I popped the hood and it looks like it is coming from the radiator I think. PLEASE DON'T TELL ME WHAT I THINK IT IS (head gasket)
ok so I just took the cover off of the top of the radiator and it looks like there is a little rubber hose on the drivers side and that is where the fluid is leaking from. Any ideas??
If it is the 5/16 soft black hose, yes, you can get it at an auto parts store. That hose should go into the hard plastic hose. You sure it's the soft hose? It could just be the clamp on the hose, too.
Where are you located? It's freaking cold here in Indiana and they all steam warming up. There's moisture in the exhaust systems and it should steam until it warms up. Does the exhaust smell sweet at all? Is it overheating or loosing coolant?
Your leak is not normal though, and as stated ^^^ replace that hose with a rubber one. The hard plastic ones are brittle and break if you sneeze on them wrong.
HA! This is an amazing quote Spike. I live in a very small town 150 miles from any Rover Dealer. I found when I go places and ask for a part for a Land Rover they usually stop me and say "What?" and I say "Land Rover....you know...British, Range Rover.....", then they just shake their heads..."No,No...we don't carry anything like that."
Then I show them what I need and they turn around and grab it.
