seamfoam alternative
will do
i think i will go make a list of what is available at the exchange and pot back up you gusy can let me know if any of it sounds ok to you as a good alternative. if not off to try and learn some mroe fo the language i suppose and search some more of the local stores....
unfortunately the issue in europe is that it is just not the norm for people to work on their own cars here.... not a lot available to the public....
Here is the flush:
http://www.liqui-moly.de/liquimoly/p.../usa_2037.html
Here are the fuel cleaners:
http://www.liqui-moly.de/liquimoly/p...t00005422.html
Go to your local SUBARU dealer and get their Upper Engine Cleaner, it is similar stuff - apparantly.
Comes in an aerosol can so it might be safer (hydrolock ).
Seafoam is not available in Australia either.
I used it and it worked okay.
You can do a search on youtube and see it.
________
Park Royal 2 Condos Pattaya
________
awesome thanks guys they have all that stuff here name is liqui moli here though
that said which one of those fuel system ones is the best bet and do you guys have any links to the directions for how to do the dead..... i run across a lot of references to it but not any actual instrcution thanks...
