seat heaters and o2 sensor/MAF
ok, which fuse do i need to replace to get my seat heaters to work again? i hate cold leather seats in the morning. the seat heaters went out at the same time as my cigarette lighter so i assume they are connected somehow..
ok, i also heard that i could remove my o2 sensors and MAF sensor and clean them with alcohol. is this true or just BS?
btw i am an idiot at this stuff so you guys need to keep your replies "fisher price" - you know simple shapes, lots of primary colors and only one letter per block...
thanks
pilsner
00 disco II
130k and counting
ft lewis WA
thanks
pilsner
00 disco II
130k and counting
ft lewis WA
Check your owners manual, there may a couple fuses to fix the seat heaters. As for the MAF, clean it and loose it, they fail when being cleaned so leave it along.
As for your 02, replace them, by mileage they are warn out.
What have you done for the rest of your truck, all fluids need to be changed, how about your plug wires, ever replace them?
Replace the plug wires with Magnecor 8mm blue wires and Champion 7318 plugs.
The fuse panel is found underneath the steering wheel. Two plastic screws need to be loosened before the panel can fold down.
Cheers,
Pete
Cheers,
Pete
Spike,
5 Nonrelated weather question is probably about enough. It is obvious this guy is not listen since he hasn't even replied to any of the replies directed at his problem.
