Sensor on top of air filter
Old Feb 10, 2008 | 05:46 PM
OxyCoRover's Avatar
Default Sensor on top of air filter
On the MAF I notice there is a sensor that leads on top of the air flow box (where the air filter goes) Are one of the leads suspost to be hot? ( i have this circuit tester and its reading no electricity going through it)
Old Feb 10, 2008 | 06:21 PM
Default RE: Sensor on top of air filter
What year are you talking about, was the engine at operating temp when you tested it and do you have a check engine light on?
Old Feb 10, 2008 | 06:33 PM
OxyCoRover's Avatar
97 Disco 1, the Engine was cold, and yes it is
Old Feb 10, 2008 | 08:01 PM
So, you can only test that sensor if the engine is at operating temp. Go get your codes read and get back to us with them.
Old Feb 11, 2008 | 05:14 AM
OxyCoRover's Avatar
The code is P1178, Will retest it when I get home from work today
Old Feb 12, 2008 | 10:04 AM
OxyCoRover's Avatar
I tested both wires when I got home from work yesterday, it showed no electricity flowing to either one on that sensor, could that be causing my P1178 code going off?
Old Feb 12, 2008 | 10:58 AM
Yes, but I am not sure what the fix is.
Old Feb 12, 2008 | 11:48 AM
OxyCoRover's Avatar
Im thinking if that is what is causing the P1178 to come up and with no juice going to either line, i will have to take off the protective covering on it and see if i can find a short anywhere.... gah now im wishing it was the MAF or O2 sensor, be easier to change it lol
Old Feb 12, 2008 | 01:29 PM
OxyCoRover's Avatar
Just curious is this what the sensor is called
http://www.roverparts.com/Parts/ETC8496.cfm
ECTS Sensor?
Old Feb 12, 2008 | 03:13 PM
S4poor's Avatar
ORIGINAL: OxyCoRover
ECTS Sensor?
"engine coolant temperature sensor". Also know as a CTS or ECTS
