Serpentine Belt Question
Old 03-24-2014, 07:08 PM
Quinn519's Avatar
Default Serpentine Belt Question
Can you recommend a name brand and type of serpentine belt for land rover disco II.
I see mine has a lot of small cracks, so its time to change.
I was told Dayco is an decent brand. Is this true?
I see Dayco has a belt with automatic corning enhancement $40 bucks, is this good?
Can you provide any knowledge and recommendations.
Thank you
Old 03-24-2014, 08:59 PM
schwaggy's Avatar
Thank you
Gates or Goodyear. Half my criteria is if it's made in USA
Old 03-24-2014, 09:21 PM
dr. mordo's Avatar
Dayco is a good brand.
However, I have had problems with a minor squeal with a new dayco on my Disco. I plan to switch to a Goodyear Gatorback, which are highly regarded for their quality and squeal resistance. They are about the same price as a Dayco, but you'll have to order from Amazon.
I highly recommend you splurge and replace the idlers and tensioner assembly while it's apart. I had an idler fail while on the interstate and badly overheat my truck in seconds. It's worth doing while you are in there.
Old 03-25-2014, 06:46 AM
gbob's Avatar
I used Rover's North (RN) and got their S belt, for my 'o3 disco. So, not sure the brand but it is working fine, having replaced it about month ago. I also ordered some tensioners and idlers from RN. All seems ok. I'll check under the hood and report back to you about the name of the manufacturer of the S-belt. Maybe Zach (ZGPhoto) can chime in? He works at RN.
Old 03-25-2014, 11:21 AM
gbob's Avatar
No markings on the S-Belt to determine who manufactured it.
Old 03-25-2014, 02:03 PM
SuperSport's Avatar
I wonder what that is? I'd like to be able to take corners faster...
Old 03-26-2014, 05:16 AM
jfall's Avatar
Yes do the ldlers if you can find a good replacement for them.
Also - buy two belts .
Keep one in the back cubby just in case.
May save you from paying the cost of a tow down the line.
Old 03-26-2014, 01:19 PM
jamestfl's Avatar
"Also - buy two belts .
May save you from paying the cost of a tow down the line."
good advice. also, check to see that you're getting the correct length, there are those with ACE and those without ACE.
Old 03-26-2014, 09:34 PM
jfall's Avatar
I remember reading that some people on here are able to remove one of the idler pulleys and then put on a shorter belt.
Taking away an idler pulley is removing a source of one more problem to break down.
Personally I stuck by the book.
But for those who are adventuresome well.
Old 03-27-2014, 12:11 AM
zeroone's Avatar
Adventures should be taken while driving the land rover. Not by making improper repairs.
Quick Reply: Serpentine Belt Question
