Service Engine Light.
I've always thought that the "Check Engine" light was the red light shaped like an engine that comes on when you're in big trouble....????
The service engine light came on recently and I've yet to have the codes read. It just makes no sense that they're the same thing. I was hoping it was a simple service interval light, but apparently not.
the DIs have a check engine light and a service engine light, as I recall. The check engine light indicates something going on with your engine or related systems, get the codes read asap and figure out what set off the code. The service engine light on the DI is a reminder to have the emission button reset. The reset button is on the passenger side either behind the glove box or just under it. Check the threads you will find the info. You need to find the small metal box, peel the sticker back and reset the button using a small pen , toothpick or something similar. The light comes on at around 85k miles as I recall. Takes about 15 minutes to get it done. Good luck. Phil
1999 DI
2001 DII
1999 DI
2001 DII
