SES P1412 and 1415 codes
Old Aug 8, 2018 | 08:56 AM
dgm's Avatar
dgm
Default SES P1412 and 1415 codes
03 D2 w/ 107K. I replaced all the O2 sensors a few months back. Now new SES light back on. Codes read P 1412 and 1415 (SAS Fault bank 1 and 2). I checked all hoses. No leaks or loose connections. Secondary air pump running. No out of the way sounds. I'll go back to parts store to get the codes cleared. Next step, see if the codes re appear. Any advice until then. Is it safe to drive.
Old Aug 8, 2018 | 09:22 AM
Best4x4's Avatar
If you’re getting those faults it’s either the line from the SAI pump is disconnected or cracked/melted, or the small lines that run from the intake manifold/SAI Valves/SAI Solenoid are loose or leaking (the 90 degree connections are famous for getting loose). Also on 03-04’s the canister is mounted over by the pump kinda high & I’ve seen plenty of those nipples broken off.
Old Aug 8, 2018 | 09:25 AM
zuke's Avatar
Or just yank off all that SAI junk and clear your engine light once a week.
Old Aug 8, 2018 | 10:20 AM
dgm's Avatar
dgm
parts store refused to clear codes...
Old Aug 8, 2018 | 10:29 AM
Best4x4's Avatar
Find another parts store! Mine would clear anything back in the day before I had my own equipment.
Old Aug 8, 2018 | 12:11 PM
dgm's Avatar
dgm
Just reset it. Now I'll see how long that lasts. Hopefully I can still pull my popup camper this weekend?
Old Aug 8, 2018 | 12:20 PM
zuke's Avatar
Or buy an Ultra Gauge for $80. It's mandatory equipment for a D2
Old Aug 8, 2018 | 12:35 PM
jobooth's Avatar
You shouldn't have any problems. It's just the SAI. Might be the purge valve or the SAI pump. Check fuses/fusable links too.
Old Aug 8, 2018 | 12:48 PM
Sean Maginness's Avatar
This was my issue on our '03. Found one of the little lines was cracked. I just used silicone tape and will replace it later.
redrover75
Jan 23, 2017 05:56 AM
passportsf
May 17, 2015 04:48 PM
Tim2
May 1, 2015 11:54 AM
sdhow
Jan 16, 2015 01:55 PM
windowrattler
Jun 11, 2013 12:48 PM
