Slabs ecu
The thing is, sensor and hub are new. I tested both front seniors and they are both good. They are routed identically aside from on the front left side I could not get it to seat where it meets the fender. I can't imagine that would do it.
http://images.google.fr/imgres?imgur...KgCFcQ9QEIJzAA
http://images.google.fr/imgres?imgur...KgCFcQ9QEIKTAB
Offroad I really appreciate the thought, but the Front Hub and Sensor are new, clean and installed identical to the front right.
I am going to go through the electrical testing procedure on Atlantic British to see if maybe a bad ground or something else is causing it electrically.
Since it is happening when I turn, and over bumps, is it possible that a ball joint on the left front side is bad and causing vibration? Or resistance?
Collie, this will be a pain in the ***, but try the following troubleshooting steps, in this order:
Swap the sensors from one side to the other, making sure to inspect the sensors for witness marks from the reluctor ring.
If the fault follows the sensor (meaning the right side now has the fault), then you have a bad sensor.
If the fault does not follow the sensor (meaning the left side continues to have the fault), then next swap the hubs from side to side.
Yes, this swapping of the hubs is the pain in the *** part. ಠ_ಠ
If the fault remains on the left side, then you should begin to look at the wiring to the SLABS ECU, or the SLABS ECU itself.
If the fault follows the wheel hub, then you received a bad hub and should see about a warranty replacement.
Good luck.
Good luck.
Good luck.
Good luck.
Collie Rover, I like your collie dog
CollieRover (08-21-2016)
