Slight coolant leak
#21
#22
FWIW guys, I have not seen any coolant on the floor since I posted this. Weird that it was after it had set for about 5 days during our vacation. But Ive put another 300 miles on it. Still runs the same temps, still get a coolant smell from the vents but I only get a very, very slight hint of coolant smell when I open the hood. I haven’t felt behind the heads yet, but I’ll get to that this weekend. I’m going to keep looking as it obviously came from somewhere!
Well, I spoke too soon. I topped the reservoir off and it was about a half inch low. Strangely my oil level hadn’t moved. But the leak is back on the ground. Leaked while cold over the weekend. I haven’t driven it for about 4 days. I’m hoping its not coming from the intake gasket but I cant find anything else obvious yet. coolant leak is hitting the floor right where the white cloth is.
#23
Motorhead1 (02-04-2019)
#24
#25
Your oil is leaking because of a plugged oil breather baggle, do the pcv mod and it will stop. It could be an intake coolant leak, but more likely hg as that is common. You can run it with the overflow bottle cap loosened 1/2 to 1 turn, just enough so the system will not build pressure, that will slow down your leak considerably.
#26
I took some time away from working on the 03 and crawled back under my 04 to look at this leak a bit better. I don’t think it’s coming from the HGs. Heater still blows very hot but the engine temps are getting erratic. I think it’s the water pump or front cover leak. It’s leaking worse now and continues to leak while parked. I put over half a quart of coolant into the bleed hole and the coolant was 3/4 of an inch low in the reservoir. Here’s some pics of the place I THINK it’s leaking and some pics of were it’s dripping from the pan and front axle. It’s wet and has green buildup. I had wiped it some before I took the pic.
#28
#29
This 04 just has the coolant leak. It throws no codes and runs good....just runs a little hot.
#30
Thanks buddy, however I’ve got two D2s..an 03 & 04. The 03 has the misfire but runs cool and it’s in another thread. It does have a very slight leak that might be a hose. I’m working on it. Misfires are #1 priority on that one.
i am on my mobile and do not have the link to the RAVE handy.
can someone post the RAVE link please?
