So close! Connecting rod bearing replacement
Old Oct 30, 2012 | 09:58 AM
arod829's Avatar
Default A couple of pictures
Thought I'd share a couple of pictures as well.
First - the bottom end of the engine back together. Note that I didn't have to do any cleaning or sludge removal here. The engine is really nice and clean inside!
Second - the oil pan. This was after cleaning out some sludge off the very bottom, but the rest of it was as clean as what you see here.
Third - just another pic of the bottom end.
Attached Thumbnails So close! Connecting rod bearing replacement-imag0184.jpg   So close! Connecting rod bearing replacement-imag0188.jpg   So close! Connecting rod bearing replacement-imag0187.jpg
Old Oct 31, 2012 | 08:42 AM
MC04DII's Avatar
How hard was this per se? Could it be done in a day in a driveway? I just bought an 04 D2 with 130k miles, but the engine was partially rebuilt last year due to a slipped liner. The main and rod bearings were replaced, but I'm getting similar symptoms that you had except that it doesn't do it at all if not under load (cold or hot). I took the cats off thinking it may be them. It helped but wasn't it. They were clogged severly though. It is a hollow (not metallic) knock sound under load when cold and very faint up to around 2k rpm when warm. Anything over that rpm I can't tell if it's there or not. Any thoughts on this would be appreciated. Thanks for this write up!
Old Oct 31, 2012 | 01:49 PM
arod829's Avatar
MC04DII - It wasn't that difficult. I'd budget two days in your driveway on your back. I had the benefit of a lift and every tool I could ever need, and the entire job took me and a friend about 7 hours for the rod bearings only. That included thoroughly cleaning the oil pan.
The most difficult part of the job IMHO is some of the sump bolts, particularly those that connect the end of the sump to the transmission bellhousing. It was tough enough getting to those with the truck on a lift - I'd hate to do those on the ground.
Old Oct 31, 2012 | 06:59 PM
MC04DII's Avatar
Thanks, I may put that on hold until I'm absolutely sure that's it. I've used a stethoscope and I think it may be coming from the torque converter. I pulled the inspection plate today, but couldn't see any obviously loose bolts. I will have to investigate more later. These things are a true love/hate vehicle. Ha
Charlie_V
Aug 27, 2015 04:43 PM
Grlica
May 1, 2013 06:13 PM
Bamberson
Oct 26, 2012 09:31 AM
DustyLBottoms
Oct 22, 2012 01:34 PM
tads
Aug 20, 2007 03:41 PM
