Spare key opens door, but won't turn in ignition
So I had a spare key made some time ago (Ace hardware), but I guess I only tested it in the door. Unlocks doors fine. When in the ignition, it won't turn at all. Goes in fine. From my understanding, the passive immobilization only disables cranking (i.e. Acc2 position -> start). Regular key works fine of course. Is it possible the spare key wasn't cut right and the ignition barrel has a lower tolerance, so I should get another key cut? I'm using Ilco key blanks from: https://www.ebay.com/itm/2-LAND-ROVE...72.m2749.l2649
I'd take it back to your Ace Hardware and have them take another crack at the key they cut some time ago. It may be as simple as a little work with a file or wire brush, but keys and wafers wear with age and as you said, tolerances vary. Or you can work on the "new" key yourself and soften any rough or sharp edges to better match your original key.
Originally Posted by mln01
(Post 692150)
Jeff,
Does your original key have a FOB? because thats what many ignitions need to "sense" to turn the engine over. I think all DII's need a FOB that is programed to the vehicle to turnover. If you need a new Key in the future consider this: I had a problem with my ignition cylinder and replaced it EASILY with a part from Atlantic British, its comes with two "retro" keys cut for the cylinder that do not have or need FOBS. It costs around $220 but thats half the cost that Rover would charge you to program a new FOB. They have a video that shows exactly how do do it. let me know if u decide to do it and if u need any advice. https://www.roverparts.com/resources...-discovery-ii/ Stefan |
Can you post a photo of the key? I had the same issue with a newly cut key and I had to grind the tip of it from the pointy end the blank came with to more of a rounded shape the OEM key had.
Originally Posted by stefanas
(Post 692164)
Jeff,
I've never had trouble starting up without a fob. Metal key works just fine.
DII keys are old school. No transponder chip.
Hey Jeff, a while back I needed a spare and had it cut.. Abran from CARS4X4 sold me the blank and programmed it for $80.
Originally Posted by Brandon318
(Post 692174)
