Spring Spacer Advice
I want to add spring spacers to the front to level out my ride but am unsure which size to install. 1/2" or 1". The truck sits nose down and *** up. I want a more level looking ride.
I am running Terrafirma HD's front and rear w/ 265/75's.
My measurements are as follows (w/ 40psi all around).
Center Hub to Wheel Arch
Front: 21"
Rear: 22"
Ground to Wheel Arch
Front: 36"
Rear: 36.5"
Front: 21"
Rear: 22"
Front: 36"
Rear: 36.5"
Personally I'd run 1" spacers up front, nothing like a better approach angle! You could run into other issues like castor and pinion angle problems, but I feel like you have castor correcting arms IIRC.
It certainly is.
Either load the back, space it at least 1 in or, get a stiffer, and taller spring up front.
Disco Mike, a.k.a. Anti-Terrafirma. Just messing around.
I know I expect some settling and will remove them down the road if necessary, but in the meantime I have to correct the California Rake I have going on.
