If I was going to go with a jeep bumper to rework this would be the one for me.
http://www.chicagolandroverclub.com/...ally%20(6).jpg 07 15 Jeep Wrangler JK Rock Crawler Front Bumper 2X D Ring Winch Plate Ready | eBay |
That looks exactly like a Disco bumper! I think I found the bumper I'm buying.
Just remember the extensions going back to the wheel well openings were added to the bumper.
Seller sold out of this one. Mssg him to see when he will get more in
(Post 506659)
No it's not mine, my Discovery is stock. My Defender 110 on the other hand :D
I also built my bumper, I have probly maxed my 12k winch, my mounts boxed the frame rails all the way back to the cross member then used grade 8 hardware, only grade 8 the bolts will probly rip the frame before breaking, 150,000 psi shear per bolt do the math
I went all the way back with the mounts so the frame takes the the verticle static weight of the bumper and winch, the bolts do noting but keep the bumper from sliding off unless I am winching, oh and my mounts are 1/4" steel If you think its overkill it might just be enough, i look at it this way, winch should be at least double the rigs weight, winch line and all recovery stuff should be double the winch, weld that are going to be stressed by that winch should be high strength, my brother in law is a union iron worker he stick welded my winch mount with high strength rod ( don't recall the rod #and psi per inch it was high), rest of my bumper I migged, it is strong probly way stronger then a lot I have seen for sale Just my .02 |
I really want to see how the rear bumper mounted, or how a d2 rear bumper mounts in general
swak6287
that is one of the nicest fitting front bumper i have seen, look like the TF only $300 cheaper, its not a bolt on, but $300 buys a lot a fab work. maybe a rear bump. 07 15 Jeep Wrangler JK Rock Crawler Front Bumper 2X D Ring Winch Plate Ready | eBay |
Looking at the pictures of how the mounts are set up to be honest I think the fab work would be pretty quick and easy to do.
Even adding the bit going back along the fenders would be pretty straight forward. It is tempting. |
