Srs and self leveling suspension lights on
oo finally got the head gaskets done and all running well but now I have that aggravating bright red srs light on the dash and the yellow or green self leveling suspension on the bottom. There are coils all the way around and it has been programmed for coil springs by the previous owner. Any ideas guys?
jason
jason
I had pretty much every light on the dash come on with mine on the drive home. The SRS came on, but I think it may have been due to cold. Since I had the air suspension programmed out, those lights haven't come on again. The 3 amigos should be sorted with option B getting performed as well as a new wheel speed sensor (I'm lazy and decided to let GBR do it) and the brake light has stayed out as well.
I'd see if you can clear the codes and go from there.
In my case the code pointed to the driver airbag circuit (I don't recall the specific code) so I got another airbag but it didn't solve the problem.
That set me on the path of looking at a short somewhere else in the driver airbag circuit. I learned that overlay harnesses are available so I headed down that path, but before I ordered the overlay I tested continuity all the way back to the SRS DCU that's under the rear of the console and lo and behold I found a short in the DCU connector itself when testing continuity back to the airbag connector by probing the DCU connector from the rear with the wires/pins still in it. When I removed the wires/pins continuity tested as it should. That meant the short was somehow in the connector itself.
Eureka!
That seemed odd to me because the cavities in the connector are designed to isolate each wire and pin, but I nonetheless unplugged the connector and carefully removed the pins, then cleaned the connector cavities with a pipe cleaner wet with rubbing alcohol and reassembled everything.
That solved the problem but I still get the SRS light from time to time. I've picked up another DCU connector in one of my trips to the local boneyards but I haven't yet installed it because removing the console is a pain, but maybe one spring weekend I'll be motivated to do it. I still don't understand how a short can occur in the connector, but oh well.
So...I was bored today and started taking stuff apart
I noticed that I have the wiring for a self leveling switch but, no self leveling button. Am I to assume that my truck is not equipped with this or that the previous owners did the disable and put a blank there?
FYI - I plan on using this blank for an aux input into my GROM iPhone adapter
