steering upgrade????
Hi all, Is there a good resource for a disco 2 steering upgrade? I just checked my steering and noticed I need tie rod and drag link ends. Of course the one off of the pitman arm is the one I need and I really would like to upgrade to something stronger anyway. I just put 265/75 r16 tires on it, so beefier steering would be nice. Any one have any ideas??
Thanks in advance
Thanks in advance
I have run 265's on my D2 on trails you have only dreamed about for over 90,000 miles and not warn out any of my steering parts, I can see by next spring I might change a couple of parts but there is nothing wron with OEM steering parts.
Well, that is good to know Mike. I do have to change one drag link end after 95000 miles. Which is not that bad in my opinion. However, I am no stranger to just about every degree trail possible. Just not in a disco 2! By the way, don't you run 3" Rovertym coils and 2" spacers in te rear for the sls?? How do you like that setup??
Actually I have a total of about 2 3/4 lift in the front with the OME 751 coils and 2 of Rovers isolators and the back has the 2" spacer from RTE with their adjuster turned up to 3 "s. Had it for 3 or 4 years and wouldn't change.
ORIGINAL: Disco Mike
