Still have troubles after front cover replacement. ..
So I had a pretty bad oil leak coupled with the oil sensor light coming on. Did the front cover gasket, new oIL gears, new timing chain and gears. Got her buttoned up and she started on the first crank. But I still have an oil leak and a little less occasional oil light. Also now have a wobbly crank pulley. Also, did not replace front crank seal- had been done by a shop about a year ago. Your thoughts? ...
1. From where is the oil leaking? Either you didn't seal everything up correctly, or the cover was not the problem in the first place.
2. What is your actual oil pressure? You should verify with a gauge to determine if there is a problem internally or if it is a bad sensor. What did the gears and cover look like when you replaced? Any scoring?
3. Are you talking the main crankshaft pulley? How much wobble? Short of major damage, I don't see how it could wobble if it slid onto the crank as it should.
Second2None
12-06-2010 05:26 PM
redhawk
09-20-2008 02:53 PM
