Strange Overheating Rover
Old Nov 6, 2014 | 07:20 PM
ems12's Avatar
Default Strange Overheating Rover
2004 Land Rover Discovery II
Just recently did a full head gasket job. Installed Top hat liners and pinned them for good measure, block and head redecked ect.
New radiator, new water pump, new thermostat. New hose clamps new throttle body heater.
Pressure tested with no leaks, bleed the system for the last 2 days and it still over heats when driven.
At idle it runs cool for hours. All fans come on. Blows hot air at idle. Drive it a few miles air turns cold truck over heats.
I am at a loss at this point.
Could it be air trapped some where? Heater core? I have never had a car or truck do this to me.
Sits at idle at normal operating temp. Drive it over heats. What gives lol?
Old Nov 6, 2014 | 08:40 PM
acamato's Avatar
Check your hoses. Maybe one is collapsing under load and reducing/stopping flow.
Old Nov 6, 2014 | 09:15 PM
Wire from the temp sender shorting when the vehicle moves? Have you confirmed the gauge reading with a IR Thermometer or ultra/scan gauge?
Old Nov 6, 2014 | 09:25 PM
04duxlr's Avatar
What thermostat did you install? Are you sure the belt and hoses are all properly routed? The hoses to your heater core are hooked up correctly? Make sure the routing of the hoses follows RAVE:
File Type: pdf
Old Nov 6, 2014 | 10:28 PM
jfall's Avatar
You have spent so much money.
and time to date.
So, spend a bit more.
Replace the radiator.
Just replace it.
Don't even analyze it.
Replace it.
When you have the radiator out - reverse flush the oil coolers and the A/C condenser with a hose.
Old Nov 6, 2014 | 10:35 PM
Colorado David's Avatar
I knew a guy who had such a problem with a RR Classic. He'd accidentally reversed the fan when he installed it.
Old Nov 7, 2014 | 12:42 AM
Dave03S's Avatar
Did you bleed the system properly, stone cold, raising the expansion tank above the engine and opening the bleed screw until a steady stream flows out?
Old Nov 7, 2014 | 03:45 AM
ems12's Avatar
and time to date.
Just replace it.
Replace it.
New Radiator as well did that Tuesday.
I'll give some of these suggestions a go and see what happens. Going to work on it today. Had to walk away from frustration. =).
Old Nov 7, 2014 | 07:06 AM
drowssap's Avatar
check the belt it can be routed the wrong way
Attached Thumbnails Strange Overheating Rover-1780133_10203270236507195_649008472_o.jpg
steveo2000
Dec 3, 2012 09:03 PM
wjchastain
Nov 28, 2012 08:43 PM
mbmbbost
May 24, 2009 07:33 PM
sparky2008
Jun 5, 2008 11:01 AM
alanski
May 11, 2008 08:02 PM
